1 - 2 of 2 Posts
2005 forester
please help! my top catalytic got plugged, i repalced the trashed turbo and it happened again...could i just hollow out the cat and get another used turbo for now?....what turbo could i use? thanks a lot!!!!!:tissue:
99 UK S-turbo
I suspect you have a fauly causing one or both failures, so perhaps it would be better to fix the root cause.
Any 2.5 Fox/Impreza turbo can be used, they are all the same, just swap on the peripheries such as the actuator from your's.
Simon
1 - 2 of 2 Posts
