1 - 2 of 2 Posts
2005 Forester XT 2.5
I have a 55 plate 2.5 XT on LPG
Replaced the Secondary air pump and shortly after was experiencing rough idle on petrol
but not when the engine auto switched over to LPG
Diagnostics error
Cylinder 4 Misfire
Work undertaken so far
Swapped coil pack 4 to 2 error remains on 4
Swapped Plug 4 to 2 error remains on 4
New Spark Plugs
New MAF sensor
Rough idle now on Fuel and LPG
Compression test shows Cylinder 4 down 9 Psi compared to other 3 cylinders
Cylinders 1-3 showing all same readings
Was thinking maybe replace the Cylinder 4 injector
Or smoke test for hose leak
Engine now sat with just plugs installed and all ancillary’s removed
Any help greatly appreciated....... or info on a decent mobile Subaru Engineer around Manchester
Switched the plug no fix, the coil no fix and then the injector and it fixed a P0304, hope this helps. 05 FXT with 140k on the clock
1 - 2 of 2 Posts
