21 - 35 of 35 Posts
2004 Forester X
Discussion Starter #21
I don't think it have the code cause I remember when I was programming a the old fob before I had to the do the turn the the ignition 10 times and I would get a honk
the dash switch panel is not something I've seen on the SG, '03-'08.
Mine has that alarm indicator from new as fitted by Subaru. If the siren is an issue there should be a little key that will turn the siren unit off in the engine bay (if it's the same as mine)
@Kevin that security system LED was on the USDM Forester in 2000, later models didn't have that. I'm still trying to figure out what security system he has in his 2004, as the usual "workaround" isn't working for him?
The security system was optional in the USDM 2004, so there's the possibility the previous owner installed an earlier security system, which would explain a lot!
2004 Forester X
Discussion Starter #26
So I had the blue and orange first then when I lost that one Subaru switched it to the teardrop
With the hood opener
@Chemically okay, you have the Alpine system that the '04 came with. That means the workaround posted on the earlier posts should have worked for you.
My concern is the LED security indicator, if that wasn't installed by you, it was installed by the previous owner. There's no telling what other modifications were done to the security system, which could explain why the Alpine security system workaround doesn't work?
2003 Forester XS
Maybe you could find the fuse for the alarm and pull it? Mind you it sounds like something is wrong if the alarm goes off when you use the key to unlock the driver's side door.
Do you have a Subie alarm or a 3rd party alarm?
Assuming your remote fob was working properly before you lost it. Perhaps now the system has glitched. It might be worth trying a system reset. Do steps 1 thru 4 on the link below.
If that doesn't work, to where the workaround works, than your option may be as I noted below.
So I had the blue and orange first then when I lost that one Subaru switched it to the teardrop with the hood opener
Sorry to say, your best option may be to do this again, as this thread doesn't appear to be going anywhere...
► Disclaimer - I'm NOT advising you to remove anything!
To be honest, I don't know? We installed the security system upgrade in my son's '03 X & as I recall, that involved removing a connector with a jumper & adding relays in addition to the security system module.
Attached is the '03 security system upgrade PDF. I'm providing this as an example of what this accessory installation consists of. NOT saying this is installed in your '04!
2004 Forester X
Discussion Starter #35
I know you're not saying to remove it I'm just trying to get the car started so I could get the brakes fixed and then I could just drive it to the dealer plug the things back in and say that I lost the fob that's all
Just something temporary so I don't have to spend so much on towing to get something done
Though I would love to do it myself but if I can't I can't and I need to find someone who could
21 - 35 of 35 Posts
