2004 forester
Hello everyone
I am a new member, so apologise if I have started a thread incorrectly.
A friend has been quoted $12 000 (AUD) for a replacement new manual gearbox from a Subaru dealer.
Could I please have some unbiased advice as to costs?
Also, perhaps some advice: she reported a whine from the gearbox, was told the gearbox was integrated with the diff, and that the rear wheels did not turn when on a hoist, indicating gearbox replacement.
If someone has had a gearbox replaced recently, or simply found that the oil needs replacing or topping up, etc, please reply.
Kind Regards
Robin
2008 Forester X Premium 5MT
I am taking a guess this price is coming from a dealer?
If so that could explain the rather steep quote. Many dealers don't have tools facilities do rebuild a transmission in house so they would "A" have to send it out, "B" replace it with a new one. I would not think that Subaru of Australia would have a hard time getting a transmission, but... Either of those scenarios could easily add to the cost.
I would highly recommend a independent shop take a look at it, a shop with experience in Subaru manual transmissions. It may take some phone work to find one. They can be rebuilt and depending on what went wrong internally it could be a few hundred dollar fix to $4-5K for a full rebuild. A replacement trans should not run more then $5k installed by a dealer, to me it seems like some one is trying to take your friend for a ride. If a replacement is needed I would also look at a used one.
You may want to try and PM BAC2.5, he is our local transmission expert.
Possibly a problem with the transfer gears? Hard to diagnose without the vehicle, but if the rear drive shaft is not turning there is a major problem in the gearbox / transfer case.
These guys rebuild and ship transmissions:
Rebuilt Subaru Gearboxes For All Subaru Models - Great Prices
Find someone to install it and you good to go for way less than A$12K
2008 XS 4EAT
Definately follow Kevins recomendations, get the car out of the dealership if that's where it's at. Most likely they would come back and tell you they can get a remanufactured transmission for less, and that will probably still be more than what you can have done at a local Subie specialist.
Ask around here, hopefully someone can point you to a local to you Subie shop that can help you out.
Good luck, keep us informed as to your progress.
Cheers
PM a few members or post here for shop recomendations near you and your prayers will be answered.
