1 - 2 of 2 Posts
2004 forester xt stage 3 vf48
So I recently changed from a stage 1 to a stage 2 cobb ots map. I have a grimspeed down pipe to a 3" cat back exhaust. With going on my test drive it boosted up to 16psi. When I map says the max is I believe 14.5psi. Just seeing if you guys have any idea what to look at to see about a possible fix? I know there is a small exhaust leak but thats it. All lines to and from turbo and on and not cracked from what I can see.
Total build:
Cobb sf intake with air box
Grimspeed down pipe
3" car back exhaust
2001 Forester STi 6spd with MapDCCD
Shelf maps can be hit and miss sometimes. You can go onto COBB's website and download a lower wastegate version of your current shelf map. This will help prevent slight overshoots like this.
Only other option is an actual protune.
honestly, 16psi isnt a MAJOR concern if you are doing pulls in cold winter temps, that will come down when the air warms up. These shelf maps will overshoot a little when the temps plunge outside.
1 - 2 of 2 Posts
