It says wheel pressure should be 29psi, that seems low. The wheels, Dunlop, says 44 max psi. What should they be? They are at 40 psi now. They were like this since I bought them. Should they really be 29?
2004 Forester XS
2004 Forester XS
Subaru's 29 psi cold tire spec probably delivers a good balance of ride comfort, fuel economy, handling, and tire life. Higher pressure will probably increase fuel economy a bit, but may result in a jittery ride.For high-speed driving, additional inflation pressure and possibly reduced tire loading and/or upsizing is required. In the absence of specific recommendations by the vehicle manufacturer, use the following guidelines based on those in the European Tyre and Rim Technical Organization Standards Manual.
For speeds over 160km/h (100 mph), load and inflation must be adjusted according to the table below.
H-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112 118 124 130
Inflation Increase (psi) 0.0 1.0 2.0 3.0 4.0 5.0
Load Capacity (% of max.) 100 100 100 100 100 100
V-Speed Rated Sizes:
Maximum Speed (mph) 100 106 112 118 124 130 136 143 149
Inflation Increase (psi) 0 1 2 3 4 5 5 5 5
Load Capacity (% of max) 100 100 100 100 100 100 97 94 91
