The Oil light on my 2004 forester xt has been flashing rapidly when decelerating or at an idle. When I press on the gas it stops lashing but then returns once I let off. I recently changed the oil pressure sending unit on my car after the last one failed, so initially i thought it was a bad connection. But i went back in and made sure the sensor connection was on properly and tight. not sure if maybe I messed up the installation or if maybe the new sensor is picking up a problem that the broken one wasn't.
