Hi guys , i do own a 2003 forester xt , which happens to have this habit of engine stalls after idle up , roughly around 1K rpm engine stalls , and when re start again it start , it only turns over but won't start , sometimes it starts and i let it sit on idle for almost an hour and it won't stall , but after i turn off the engine let it sit for a bit of time , it won't start again, it seems that if it wants to start it will start without drama and if it doesn't want to starts it will not start , already on lost with this problem no fault CEL .:frown2::frown2::frown2:
Fuel pump replace
Camshaft sensor replace
Redone timing
Check clean all groundings
Check engine harness continuity all good
Fuel pressure check holding pressure
Clean MAF and Throttle body
cleaned and replace crank sensor from donor car
Replaced alternator
Replaced spark plugs
And the button for the remote keyless is missing so i open the door manually by key .
Fuel pump replace
Redone timing
Replaced alternator
