Hi y’all. I am about to change the oil for the first time on my FXT. It has 187k miles and has always used conventional oil.
I’ve found conflicting reports on the use of conventional vs synthetic oils. Some say synthetic oil runs better in a turbo engine. I’ve also read about instances where turbos have failed after switching to synthetic, and in turn switched back and gained better engine performance.
Originally I was going to go with an OEM oil filter but I’ve also seen conflicting reports on the integrity of these filters.
Your knowledge and recommendations are much appreciated. Thanks!
