2004 2.0 XT AT
Hi,
I have 04 forester xt, and i`am having issues with the brakes/abs .
When i drive slowly and apply brakes, not gravel or snow, just on tarmac. The brakes starts to pulsate,like when ABS kicks in during hard braking. And the bearing,pads and rotors have been recently changed.
So i pulled the ABS fuse, and took a drive and now it acts normal. No pulsing, no noise and brakes fine. And the brake pedal is not sinking.
What could be the issue here? and what can i try to test/do? I`m suspecting that the abs pump is at fault .
Thanks for replies!
2016 Forester Premium
Any update? My ‘16 has pulsing issues, but only downhill & above 40mph. I just posted but I won’t hold my breath for reply. My brakes are good, disabled my ABS & problem went away, but that doesn’t narrow it down to a component, or even the ABS as faulty suspension might be setting ABS off. Hope you found a solution
