2004 forester XS luxury
Hello. I bought a set of 215/75r15 Hankook dynapro's for my 2004 SG forester XS on stock suspension only to find out that they rub heavily with minimal turning of the front wheel. I was wondering if anyone has had the same experience and if a 1" lift spacer is enough to fix it. I'm running 15x7 rims with a 0 offset also
G'day & Welcome @James092924
What 15" wheels are you running and what is the offset?
Yes, you need a pretty big lift to compensate for that side tyre. I am running that size with custom suspension and it will still rub on right full lock. (2"lift; custom struts with Koni inserts and raised spring perches; kings HD springs; trailing arm blocks)
For my next set I am thinking I'll run a slightly smaller size possibly 225/70R15
