Hi
I am going to look at used one below in used car dealer. What are things I should check during test drive.
Thanks,
$6,550 ... 2004 Forester 2.5X Green ext., Tan Cloth Int. w/ Leather Accents
FREE State Inspection & 1 Month Bumper-to-Bumper Warranty
120,000 Miles
Clean Inside and Out -
1 OWNER Clean CARFAX Certified and comes with a full CARFAX Report
NEW TIMING BELT
2019 Forester Touring
I have an '03X AT w/ 129K and love it.
Both of the cars sound like they might be good. Either would need the timing belt replacement at 105K miles so the first one sounds like it's already had it done.
Both cars are externally identical as the newer "soft" front end came online in 2006.
Check to be sure the the head gaskets are NOT weeping....a mechanic can do that, especially a Subie-capable one.
I'd prefer to get one that has all of the maintenance records so you can see what was done and when, especially the oil and filter changes and radiator coolant services......
Best of luck,
Steve
2008 XS 4EAT
Do you have a budget in mind and would you consider going outside the Boston area, even to another state nearby? Since you are near a large metropolitan area the prices seem higher than lets say NH.
And as far as the timing belts make sure they have also changed the idlers and tensioner, those are likely to fail before the belt. If the belt has not been change you should be able to work down the price so that you can afford to have it done.
Keep us informed here as to what you found with the ones you are looking for.
*****I stand corrected pricing seems pretty close in neighboring states
