Hey everybody. 03 forester 220k on frame 80k on motor. Started hurling hesitating. I have replaced the following. Plugs,wires,coil pack,cam sensor,crank sensor, tps sensor,fuel filter and checked everything else on the spark and fuel systems. Compression is 180lbs on 2&4. 195 on 1&3.
while in the studder if I pop the into Neutral I get perfect response from the motor.
the codes it’s giving is cylinder 2 misfire.
timing belt has 20k on it.
Any ideas
2003 Forester 2.5X 5 MT & 2009 Impreza 2.5i 5 MT
Pull the spark plugs one at time and take note if there is anything wrong with the electrode on the spark plugs. Also examine the spark plug boots if there is oil on any of them, then most likely your spark plug tube seals are leaking oil and this is causing the problem
