1 - 7 of 7 Posts
2004 XT JDM
This may be more of a general transmission question, but anyway:
When driving through residential areas, if I slow to make a 90deg turn (so 10-15mph), the engine will slightly rev and then thump itself back into gear. Not all the time though.
Is that an indicator I need a full transmission rebuild?
2004 XT JDM
I just went outside and checked, a little surprised at what I found.
Car is completely cold and:
  • diff fluid is clean, slightly above full line
  • trans fluid is clean, but filled above full on HOT marks
I'm pretty sure that could be a problem in itself, right?
2017 2.5i Fozy CVT
Yes, but check it when it is hot, too, been awhile since I have seen a trans dipstick... the COLD LEVEL is below the hot, right?
More than 30k miles on the fluid, then drain and fill. No flush.
2004 XT JDM
Yup, cold is the first two pinholes, then a gap, and another two pinholes for hot.
Car only has 50km on it which is right around 30k miles. No idea on age of it.
2019 Crosstrek 2018 XT
Engine must be running when checked.
2004 XT JDM
Discussion Starter #7
Just wanted to follow up on this, I checked the oil levels again this weekend when the car was hot and running. Diff and trans oil were both clean and within the correct ranges.
With that being said, I noticed something else while on the highway. At 120km/h actual speed my speedometer is reading at almost 130km/h and the tach also seems to be higher than it should (going by my ear). Tires and wheels are stock setup.
I'm wondering if perhaps there is a speed sensor somewhere on the transmission that is failing, and if so, it could be contributing to the first issue I noted here?
1 - 7 of 7 Posts
