okay,
Lets begin...I have an 02 forester with a 5s Manual transmission. Today I removed the propeller shaft. (the driveline that starts at the transmission and ends at the rear differential. This is what I know, the u joint that is connected to the rear differential is shot, Its bad folks. Anyways. I have pulled the entire propeller shaft out of the car and am limbo on the next step. This is what I know, the u- joints in my model are machine pressed. the factor says you have to buy another shaft and cannot replace u joints like other cars. However, I have seen online people doing it, as well as, found a company that sells u-joints engineered for this purpose. Changing the u-joints is option 1, however, I am afraid it may be over my head. So, my next option was to pull a drive axle out of a junk yard. Well, guess what. Manual drive axles are shorter than automatic drive and their are not any manual drive axles near me within a two state radius. This is my question, I noticed that the propeller shafter looks as if it could disconnect at the center rubber bearing. Has anyone ever heard of doing this???? Reason being, I could in theory pull an driveaxle out of an automatic and separated the drive axle, reassemble it on the front part of my drive axle and in theory they it should be the right size, considering the length difference appears to be from the center bushing to the transmission. Is this possible? If not are their other models in the junkyard that I could use that would be the same fit? I know thats alot to follow but any help would be very appreciated. I need to get this baby up and running, I work in the gig economy and every day she is down is a day I am not making money. I could buy a shaft online, my concern with that is the time it will take to ship. Any suggestions, as always, would be very appreciated.
Roll on fellow travelers, keep your head up and your face in the wind!
