I Took the the alternator off and had it checked TWICE and it is charging fine. (75 amp alternator 14.5 amp charge and all components working fine). Put alternator back into vehicle and it is only showing 4-5 amps on the battery cables. I assume it is a ground problem. I will be checking the battery cables first but don't know where to look after that!!!
Does this model have a voltage regulator? If so where, I see nothing resembling a VR anywhere, unless it is that odd looking device on passenger side fire wall? If that is it how do I check to see if that is the problem??
Any help is appreciated!!!
Jimmy
Jimmy
