My SF sits about 1'' lower in the rear (measuring from the ground to the top of the fender well). This drives me nuts and I'm trying to figure out the best way to fix it without refinancing the house. I don't want to use spacers above the rear struts because I like the height in the rear, I just want to drop the front roughly 1.5.'' I have some Tein Coil springs that I pulled off of some 2002 wrx front struts (part # on the springs is F-P1S60-OUO). Based on the ride height of the car I pulled these off of I believe they are lowering springs (green in color).
My questions are these:
Will these springs swap onto my SF struts without modification?
Will this effectively lower my SF 1-2'' in the front?
Will I be compromising handling or causing the struts to bottom out?
Any help answering these questions is greatly appreciated. Thanks in advance.
