2001 Forester
Does anyone have the ignition coil wiring diagram in color for a 2001 Subaru forestor? Currently the car won’t start, checked the fuses they’re good, check the spark plugs and no spark. I have fuel pressure though. Checked the ignition coil port and it’s producing half of what is necessary around 6. Was gonna change the pack and test again but the next step is the wiring of the ignition coil. Really need the diagram. If it isn’t a fix from there I’d prolly do the crank then cam sensor. Also jus started happening I think it’s a separate issue is when I would try to start the car then take the keys out, all my dash lights are on. Only sometimes would my fam jus start running out of no where. Only fix was unplugging the battery. I believe it’s a short but where. Need help!
· Administrator
2001 Forester
