Hello everyone,
I'm currently lifting my '01 Forester with the above mentioned springs. I got the front installed using Monroe OE spectrum struts and I'm pleased so far. However, I'm having issues installing the springs on the rear strut. The coils have a flared end that doesn't match the size of the top hat. It appears once the coil is mounted under tension, it might slip loose and misalign. Does anyone have any experience installing these springs? Do I need to purchase a different strunt mount that's sized correctly? The stock springs appears identical top to bottom. Someone had previously asked the same question but it went unanswered, it seems. Any help would be appreciated. Thanks!
