2001 forester key transponder
1256 Views 3 Replies 2 Participants Last post by  joey_turbo
can some body help me with a problem I have with immobilizer.after changing clutch ,battery disconnected for few days,car started for a moment then stopped,it cranks over but fails to start
What country are you in?
Different immobilsers in different countries.
How did you change the clutch, engine out or gearbox off?
If it was the transponder key, it would be flashing up on the dash. Have you checked for spark?
I would pull out the leads to check, just to rule the immobiliser out. The key transponder cuts the fuel, so you wouldn't hear the pump prime if it was that.
