Hey all,
My clutch was not engaging in extended city use , possibly due to age and the metal expansion in the heat. I tried to remove one of the shims in the clutch assembly using the Mr. Subaru method to reduce the air gap. Could not find any hardened M5 bolts. I tried with hardware store metric bolts, but should have known better than to use those. after tightening to force the disc off, one of them snapped and became stuck. At this point could I use a hacksaw to cut the bolt through the air gap so it can at least go back to being partially operational until I can get it to a shop?
In the worst case, would it just need a new clutch kit to permanently fix this?
Thanks for any advice.
