1 - 2 of 2 Posts
2001 Forester S auto
Does anyone know how to SAFELY clean the inside of the flapper and the crevice around the filler pipe? Mine is DIIIEEESSSGUSTING [sic]. Is there a non-corrosive solvent that can be used IN SITU, instead of removing the flapper or the plastic collar around the pipe? Thanks guys.
@SueBrew we clean ours every time when we wash the Forester, same car wash soap. A detail brush does a pretty good job or an old old toothbrush will work. :wink:
As long as the gas tank cap is on tight, the water won't get into the tank, it will drain out the built in drain.
1 - 2 of 2 Posts
