Hi Gang,
I recently installed a Turn in Concepts linkage update in my 2001 Forester 5MT, since the install I have had a hissing noise coming from the transmission which is only audible in 4th gear. The noise starts as soon as 4th gear is engaged and does not change when the clutch is depressed/released. It is most noticable around 3k rpms and gets louder as the revs go higher. This sound was most definitely not present with the old sloppy linkage, any help and suggestions are much appreciated. Thanks!
