1 - 7 of 7 Posts
2000 Forester
Thought I had this cleared up with the fluid change. Guess not.
I've done four 4-quart changes a few days apart, so the fluid should be good. And I've changed the filter.
Whenever the transmission down shifts for power, I get a harsh jolt. I think this is happening at 4-3 and/or 3-2. I often get the jolt as well on the subsequent up shift.
Taking off from a standstill and accelerating through the gears is smooth, even at full throttle. So is the down shifting that occurs when I slow down. It's only the down shift for accelerating that causes the jolt.
I've read through everything I can find on this site, but most posts seem to pertain to the newer direct control transmissions.
Any ideas?
Thanks
2001 Forester S automatic
I had a similar problem in my '02 with 130K. I changed the front and rear differential oil and added half a bottle of Motorcraft friction modifier to each. It didn't completely eliminate the hard shifting or slipping, but it have me about 80-90% improvement or so. I was surprised how much it helped. It's cheap, so it's worth a shot.
2005 Forester X
My 05 w/auto does this too. Its not very smooth shifting under load. It only has 46k on it.
2000 Forester
After driving it longer it seems that the jolt is from 3 going to to 2, and often again on the upshift.
I'm going to try the gear oil tonight if it doesn't rain. Hope it helps.
none none
What filter and fluid did you use?
Also make sure the trans actually has enough fluid, slightly low fluid could cause some similar issues.
2000 Forester
Discussion Starter #7
It helped a bit, but not enough. It still slams pretty hard and chirps tires from time to time.
I've had two mechanics (not trans specialists) suggest a solenoid problem. So I'm going to check into that next.
1 - 7 of 7 Posts
