2000 Forester
I started having some trouble with my 2000 forester today.
It was running fine all weekend then today the check engine light came on while I was driving, and a few seconds later the engine died. The oil and emergency brake idiot lights also came on.
Now the car will start and idle for five or six seconds and then it will sputter and die. If I try to give it gas it will also die. While it is idling for those few seconds the check engine, oil, and ebrake lights are all on.
Any ideas what this might be or things I can look at to help diagnose this?
Thanks!
2001 Forester S
Weird. Hard to connect all the warning lights. Did one of your belts break or slip off a pulley? Are the connections to the battery good? Could the engine ground have come loose?
Did you retrieve the Diagnostic Trouble Code that caused the Check Engine Light to come on? That would be most informative since it coincided with the failure.
2000 Forester
I looked under the hood and the blets seemed fine. I'll check the battery connections, before i head back out though, how do I get the diagnostic code? do I need a special tool to do that?
05 FXT 5MT
You need an OBDII code reader. They can be had cheap at most any discount parts store and can likely be returned as well. It sounds like maybe the MAP sensor died, froze up or otherwise quit working.
Unplug it (should be on top of the manifold, to the right of the coilpak) and start it up. See if it continues to run. If so, get the code read so you can diagnose it.
