So my engine is a SOHC. Does anyone know what the engine is called? Is it a EJ15?
Isnt a EJ25 a DOHC engine? Im really confused as to what engine I have in my car. When I searched the Vin# on car fax it says that the car has a DOHC. When I call the dealer they say SOHC 2.5L. I just want to make sure I buy the right engine. Would pictures help? Or is there something on the block that say EJ25 stamped on it?ej25. It's a 2.5 liter engine.
Any EJ25 SOHC will fit with a little bit of work, some can be a direct drop in others will require swapping a few items over, which can be used as a good time to do some basic maintenance on a engine you don't know the history of..... I just want to make sure I buy the right engine. Would pictures help? Or is there something on the block that say EJ25 stamped on it?
