Since acquiring my 2000 Forester last fall, it has had an annoying clutch squeal and chirp.
The chirp occurrs when the car is idling and is in neutral. It is a repeating squeak-squeak-squeak-squeak, maybe 2 high-pitched squeaks per second.
The squeal occurrs when I push the clutch in for the first 3/4" or so, and sounds exactly like a squealing belt. It isn't a squeak, and I can hear it much better when the windows are down, indicating to me that it is coming from under the hood or under the car rather than inside the cabin (such as at the actual clutch pedal).
To further aggrivate my clutch woes, every now and then the clutch pedal may fail to return and has almost no resistance for the first few inches of pressing it. Although, I did find a TSB for this on this website, which sounds exacly like my problem and I plan to fix it.
FYI, the Forester has just under 95,000 miles on it and the PO (a family member who I trust) said the clutch was replaced around 85,000 miles at a Subaru dealer. I'm not sure if they also replaced the throwout bearing and fork....
