What would need to be done to put a 2003 ej20 in to my 2000 forester gt as my car runs coil pack as 03 runs coil plugs the 03 motor lm looking at is out of a Impreza but comes with wiring and ecu is it a easy swap
@Timmy A swap such as turbo to NA or visa versa is not easy as yes, you have to swap the wiring harnesses, ECUs etc. If you can afford for the vehicle to be out of action for a long time and take it on as a project then it can be done. You would also need to determine if the transmission is compatible as well.
My car is turbo 2000 model can’t find a motor but can get 2003 imprezza ej20 turbo the lot ecu wiring the lot
