The earlier ECM are pretty basic... no serious magic. As long as the ECM is off a like Forester, you should be good.
Did you check the radiator thermofan switch(es)? on the radiator?
The sensors referred to by karlaudi did not exist on either of my Subarus therefore I doubt very much they would be on your vehicle. The workshop manual for MY'03 (incls non-turbo and turbo) refers to just one "Engine Coolant Sensor". As well there is the "Intake Air Temp Sensor" and the "ATF Temp Sensor" but I cannot imagine either of these stopping the fans.I'm putting it up on ramps today and I'll try to locate the sensors that were referred to in an earlier post.
I did the diagnostic test and the fans function.
You said the coolant temperature sensor had "3 prongs". Did that sensor have 3 wires or 2 wires?Yes. I replaced it last Sunday. It was the one in the back of the engine under the intake manifold. It had a three prong connector. It didn't seem to make any difference. <snipped>
The only code was 'fan malfunction'. I forget the number. I should have written it down. I kind of remember it was 1408, or something close. I just put my scanner on it and it read no codes. Even though it has been started and got hot, but not to the red mark.Yes, they did both come on Bobby.
It would be interesting to see if any old codes exist.
I don't believe that I have a scanner that can perform that function. I'll probably need to buy one. I have a Schwaben by Foxwell. It is set up to read OBDII, as well as BMWs.@Derek'sForester questions:
[1] Just to verify... when you connected the green test connector, did the both radiator cooling fans operate?
[2] Have you read the coolant temperature with a scan tool, Scangauge II or an UltraGauge?
I stand corrected, Kevin. Except for my very first car when I was in the Navy, and then only for a few months before I bought a VW (it was a 1964 6-cyl 2 dr. Chevy Bel Air), VWs and Audis are all I have owned since 1976. My first water-cooled VW was in 1981 and I was also working in a shop at the time that focused only on German Cars and then mostly VW and Audi automobiles. I have seen a lot of thermofan switches in my day.The sensors referred to by karlaudi did not exist on either of my Subarus therefore I doubt very much they would be on your vehicle. The workshop manual for MY'03 (incls non-turbo and turbo) refers to just one "Engine Coolant Sensor". As well there is the "Intake Air Temp Sensor" and the "ATF Temp Sensor" but I cannot imagine either of these stopping the fans.
If the car needs to be used just run direct fused power to the fans with a switch under the hood. I did this as a temporary fix in the past.
The wiring diagram shows a 2 wire coolant temperature sensor, so your "3 prong" description threw me.It's really hard to see, but as far as I can tell there are two, a green one and a white one. I'd have to disassemble the ducts leading to the throttle body again to get a better look.
There is a heater bypass hose from the water pump so the heater can function without coolant flowing through the thermostat.I always thought that if the heater worked that meant the cooling system was circulating the coolant well.
