1 - 20 of 60 Posts
2000 Forester S Automatic
My son's Forester has a fan problem. They don't come on. I did the diagnostic test and the fans function. That means the fuses and relays are working properly. I replaced the temperature sensor, not a fun job, but still they won't work upon warm up, or when the A/C is turned on. Any ideas where to look next? Help.
engine fans won't turn on in normal conditions.
I keep trying to post questions here, but only one has ever showed up. I still need someone to try to tell me if there are two temperature sensors for the electrical radiator fan unit and where they are. I have replaced the coolant temperature sensor under the intake manifold. I have also used the green wires under the dash to show if the fans work. They do, but not when the A/C is on or when the engine gets hot. Is the ECU the only thing left?
2015 Forester 2.5i Premium 6-speed manual
Thermofan switches are most often located in the bottom tank of the radiator close to the lower hose. Or the lower radiator hose on side tank radiators. They are what turns electric radiator cooling fans on according to coolant temperature in the radiator. Check your thermostat too if no hot coolant reaches the radiator so that the fans turn on.
You may wish to see if a Subaru Service Manual is available from Subaru for your model and year. The price is right for downloading a PDF manual plus other information.
The link:
https://techinfo.subaru.com/stis/#/login
· Administrator
I keep trying to post questions here, but only one has ever showed up. <snipped>
No need to create a new thread when you already have an active thread on the same subject. Per the forum posting rules, your threads have been merged.
Again...
For the best forum experience, we recommend completing your "Account Details". The optional information you enter there will display when members click "About" in your forum profile. You can also create a custom "Signature" that will display every time you make a forum post. The optional additional information you provide could mean getting forum member replies, or not.
I am new to your forum and I am sorry if I didn't know some of your rules. I just wanted to find some information. I am not new to Subarus. I've owned two SVXs as well as having done several timing belt replacements on this particular engine. I'll try to follow your rules from now on, if I have broken them. I just wanted some help.
· Administrator
@Derek'sForester did you read this on my previous posts?
· Administrator
@Derek'sForester if connecting the test connector verifies the main & sub fan are working, then that appears to be pointing to a ECM or sensor issue. Note that the fans are controlled by the ECM & not directly by the test connector or sensors.
Also...
Is this fan issue a new problem that just started up?
'99-'02 Forester
Discussion Starter · #13 ·
It was intermittent for about a week, now it's all the time. We haven't driven the car in more than a week at this point.
I replaced the temperature sensor at the rear of the engine last Sunday. No change.
Thanks for the wiring diagram it helps. I ordered a Haynes manual and should receive it tomorrow. I'm putting it up on ramps today and I'll try to locate the sensors that were referred to in an earlier post. If it's the ECM then I guess the car is toast at 215,000 miles.
Discussion Starter · #15 ·
Thanks for the information. I'll clean them up when I'm under the car, but it was my impression that if the fans start doing the diagnostic it wouldn't be a connection problem. I've had Subarus before, but never had an issue like this. Of course I've had SVXs and worked on Outbacks, but Foresters are pretty new to me.
· Administrator
Not saying the ECM is bad, but they can be found used at a reasonable price. Just make sure the vehicle it came out of matches your Forester, especially MT or AT.
Discussion Starter · #20 ·
Yes. I replaced it last Sunday. It was the one in the back of the engine under the intake manifold. It had a three prong connector. It didn't seem to make any difference. I just ordered an ECU, am I going to have to get the the unit recoded to make it work. It's a 2000.
1 - 20 of 60 Posts
