1 - 11 of 11 Posts
No more Foz !
03 Impreza Sti
Anyone know the rating for the standard fuel pump that comes with the 06 2.5 FXT ?
I believe the injectors are 550's..
Cheers
Pete
11 sec club
04 Cayenne TT
I'm running a Walbro 255. I wasn't sure what the stock one flows but I knew it wouldn't be enough down the road.
The injectors are thought to flow 550cc. No one has flow tested one off of an 06 yet but Cobb extrapolated some data when doing the AP programs and they thought they were 550s from the injector duty cycles.
No more Foz !
03 Impreza Sti
Thanks for the info - might drop one in just to be safe.
I notice you're running a WRX IC - What's you're view on how far it's safe to go with the stock one ? I'm probably only looking to get to 330/330 at this stage with a VF39/Prodrive exhaust/filter and remap..
Many Thanks
Cheers
Pete
2008 SG Model D
Many Thanks
Cheers
Pete
I say go w/ a larger top mount for that kind of power...the WRX TMIC is slightly better than the FXT TMIC but unless you go big, you will get crazy heat soak. Wrapping the hot side of the VF39 will help w/ the heat soak.
No more Foz !
03 Impreza Sti
Thanks again :)
Does the WRX intercooler go straight on with no modding ? What about one from an Impreza sti ?
Good tip on the wrapping :)
Cheers
Pete
2008 SG Model D
Many Thanks
Cheers
Pete
FYI, unless that is power at the crank, you will not be seeing 330/330 at the wheels running a VF39.
11 sec club
04 Cayenne TT
Cheers
Pete
It does not go sraight on. The mounts are different and I had to modify a splitter and make a separate 'skirt' for the splitter to direct the air onto the core.
2004 XT
i had to do the same. I went to home depot and cut the handle off of a trowel and drilled a few holes in it and attached it. works just fine. a little ghetto (maybe alot) but it does the trick and only cost a few bucks!
be sure to get all the hardware first because the BOV is not a direct swap!
11 sec club
04 Cayenne TT
Weird. Probably another difference on the 06 because my stock BOV bolted on perfectly to the WRX unit. However, the WRX unit is on it's way to a new home and I'm waiting on an APS top mount now.
Aspiring Post Ho
Unless you drop alky injection on it! I think it would be possible that way but other than that it will run out of steam right at or near 300. There are afew of us that have tried and come close but no one on here has pulled 300 with the vf39 yet.
No more Foz !
03 Impreza Sti
Discussion Starter · #11 ·
Yeah - sorry, I keep forgetting you guys measure at the wheels..
330/330 is at the crank..
Cheers
Pete
1 - 11 of 11 Posts
