First time posting in the forum but a long time stalker of all your useful guides. As many of you know the lateral link bolts is the devil's butt hole, I bent my rear control arms earlier in the year trying to save my pregnant wife who got bogged down in the snow, who knew that bald summer tires have 0 traction on 3 inches of fresh snow on a freezing day.
see pic of my crazy straw looking control arm
Please ignore how rusty and horrible my rear suspension is I'm planning on replacing all of it in the future once shes back up and running.
I was successfully able to get the nut off the end of the lateral link bolt and hit the end of the bolt with an impact gun (800nm) after soaking it in penetrating oil and attempt to got at varying torque settings to prevent snapping the bolt. When the bolt just span in the bushing I thought the breaker bar with a long extension so used an old bit of steel pipe and the breaker bar but this didn't do my bar break the steel pipe and split it along the edge. Stupidly I thought maybe something smaller would work so genius over here decided to use a 3/8" ratchet to get it off which was the biggest mistake. Que the explosion of a socket and shortly after the rachet itself which gave me ringing ears for a day.
It got to the point where the end of the bolt had started to round and I began to struggle to get a socket over it, so in came every mechanics favourite tool a blow torch and angle grinder. I was able to burn the bushing off the bolt head end and cut the rest of the sleeve off which was good tried to hammer it out with a punch but no luck, I then wanted to start on the other side but an assortment of wire and cable was located so close to the other end I didn't want to add more work and cost to the job by melting these unknown wires and cables.
Currently praying I can cut the other end of the bolt off which still has the control arm attached and try and hammer the bolt out hopefully breaking away at any of the corrosion in the knuckle. Worse comes to worst ill probably detach the trailing arm and driveshaft and just scrap that knuckle in favour of one that doesn't have the lateral link internally welded in.
