Today I went to leave the junk yard and my 99 SF6 wouldn't start. Luckily there was a lot of car guys around to help, lol. It's done this a few times before but I had never suspected the starter until now, it always would fire up after a few tries and I figured it just needed a couple seconds to build oil/fuel pressure. Now I'm thinking all along that the starter may have been going out.
The battery is new, about a month old. I have a voltmeter wired up inside and the voltages look normal (although I know that doesn't give you a full picture without the amp load as well). When I turn the key it will make a click sound but no cranks, there's never any cranks when it's having this particular issue. I have a portable lithium jump starter and it didn't seem to help at all, no cranks. Another guy had a car battery sized jump starter and that didn't help either.
Had a guy help me push start it and it fired up, so I was able to get home. When I parked it I tried starting it a few times and it fired right up each and every time.. Right now I'm waiting for it to cool off to see if I can reproduce the issue because I've heard that a dying one will fail more when it's colder, but I live in socal so there's not a lot of opportunity to test out cold temps.
Being that I'm a noob, what do you guys think? I was thinking the starter itself because it's intermittent & that jumping it didn't help. I have a multimeter and I'm hoping I can get it to start failing again so that I can test it, but either way I think I might end up pulling it & cleaning it with a wire brush. Never messed with starters before so any advice or ideas are definitely appreciated!
