Hi everyone,
It has been a while but now I need some advice. I am on a road trip for research my Masters when things started going wrong.
I drive a 1998 Subaru Forester S auto (Dohc) with 200,900 miles as of writing this. Before leaving I checked my oil and it was at the L, I added a bit to get it to f @199500 miles(been having trouble with oil loss, see history below) I left my city in Kansas when I got a flashing CEL. I pulled over and then checked the manual. I then restarted and the CEL was solid and drove to a Subaru dealer in Wichita KS. They looked at it and charged $100 just to look. It was a misfire on cylinder 4. They recommended plugs and wires.
video of inspection:
6309842
I had changed the plugs about 15k miles ago so I figured it was the wires. I actually had a cheap (aftermarket) set of wires and a coil in my car as a just in case. I swapped the wires and went on my way. The CEL stayed on but then went off. I then was on my way to Austin Tx and I started to get overheating issues. Temp kept creeping up but I never let it go in the red. I would either back off throttle or pull over. I added more coolant as needed. I made it to Austin where the car ran fine for 3 days. I then left for Albuquerque NM when after an hour I noticed mist from the hood. I was confused and then noticed the temp gauge was past the red. I pulled over and popped the hood and one of the radiator lines burst and had sprayed coolant all over the engine bay. I then had a tow truck tow it to an autozone where I bought a new hose, which didn’t quite fit right so had to cut off 2 inches from each side and swapped it in. I checked the fans and they work. The oil was again L so I topped it off and I refilled the radiator at about 200250 miles. I then went on my way and temps seemed fine. I then got a blinking cel again on the road at around 200800 miles. I pulled over and everything seemed okay. Made it to Albuquerque NM and the next day (today) I swapped to a cheap spare coil pack. Got it installed and idled fine but when I went to R or D it ran terrible. I then parked and swapped to the old coil pack and it seemed okay but was getting some Hesitation or misfires when pulling always from lights. I went to autozone and had them check the codes. P0304 and P0303. They recommended plugs. So I’m just stumped. Are the problems related or separate? Should I need new plugs after 15k? Should I just pickup an oem coil pack and wires and swap them? Any advice would be helpful since I still have to make it all the way back to Kansas and then St. Louis in the next couple weeks and I really can’t afford a big repair.
tldr:
last 20k car history
@~184,000 12/27/20
-I had a split cv boot and power steering boot so I swapped the cv axle and replaced steering boot.
-Changed the spark plugs with nkg iridium lx
-got an alignment
@~187,000 5/13/21
-I was getting concerned about oil loss and noticed coolant drips. My Forester also needed a new timing belt so I brought it to a dealer in St Louis.
I indicated that I thought it might have a blown head gasket since I’m seeing both coolant and oil loss. They looked at it and determined it was camshaft seal, valve cover, oil pan and baffle plate are leaking as well as the water pump is leaking.
had all that fixed with an engine reseal, timing belt and water belt replacement. Cost $~2800
@~193000 8/22/21
-I noticed oil leaks/ excessive oil loss and that my transmission pan is dented.
-My oil change place also brought this to my attention.
-I brought this concert to the dealer and they looked at it. They used dye and found no new leaks and stated that it was residual oil and that the transmission pan was not a concern.
@199000 11/26/21
Oil continues to run low. I changed the oil and I measured it was about a quart low.
@199500 12/15/21
oil was L and I topped it off.
Driving for tx when Car had check engine light flash then solid.
Went to Subaru dealer in Wichita and the suggested plug wires for check engine light.
Identified oil leak and said on engine craddle. Oil is coming from top side.
Changed plug wires in parking lot.
Check engine light stayed on then stopped.
On the road and Started to get near overheating 2 or 3 times.
12/16 - 12/17/21
No issues in Austin TX
@200257 12/18/21
Left Austin and car started “smoking”
Car was overheating, no warning light, and coolant All over engine bay because a hose burst open. Oil was also low again. Fans seems to work.
@200819 12/18/21
Check engine light blinked and came on
@200909 12/19/21
Changed the coil pack first thing but ran rough so swapped to the original old one. Solid check engine light still on but might be from before.
Went to autozone and had them check the code. Codes were P0304 and P0303, cylinder 3 & 4 misfire. They said it just needs new plugs which is what Subaru said but they were changed around 185000.
6309842
tldr:
@~184,000 12/27/20
-got an alignment
@~187,000 5/13/21
@~193000 8/22/21
@199000 11/26/21
@199500 12/15/21
12/16 - 12/17/21
@200257 12/18/21
@200819 12/18/21
@200909 12/19/21
