1998 Forester
Howdy!
I'm the lucky candidate to install an inner tie rod end on a 1998 Forester.
Unfortunately it seems that the tie rod #101-4471 (IIRC, listed for '98-02 Foresters) doesn't match up to this particular vehicle. It's ~3" too long, and the inner threads to the rack are too fine, mine are smaller and coarser.
Being that this is a '98, i'm wondering if i got an early production vehicle? Also, this vehicle was in an accident and poorly repaired, it's possible that the rack came off a junkyard car (if there's anything that would bolt up).
Any thoughts? I'll take anything, anything you can throw at me! :banana:
02 Forester L (sold) Manual
Inner tie rod is the same 98-02. Same as Impreza 98-01. Same as Legacy 98-99. Two ideas...you either have a rack from a year not covered in the above, or L and R are different part numbers and possibly the length is different, so you may want to check that you got the correct side.
Edit: that p/n is not genuine Subaru, so can't cross it for you.
1998 Forester
Thanks for the response!
I'll check the other side and see if it's side-specific.
My research has agreed with what you said--everything is the same from '98-onward, so that's where my confusion is coming from!
Maybe it's time to start digging through the books...
Thanks,
Chris
1998 Forester
Just a quick note:
Found an inner tie rod end that works, it's from a '97 Impreza. I don't know if this means that the rack is from an impreza (due to the accident), or if this is an early car that got a few leftovers from the parts bin, but....either way, it is what it is!
:catfight:
Thanks,
~CHris
Howdy!
Any thoughts? I'll take anything, anything you can throw at me! 🍌
I have an 04 Forester X. I just ran into the same problems with the threads on the inner tie rod. Have to find out what the issue is.
