Hi Guys. Here's some back round. I bought a 1998 Forester in mid January with 145,000 miles. In 2008 at 140,000 miles the head gaskets and timing belt had been replaced to the tune of $2300. Soon after that the owners got rid of the car as the catalytic converter quit. The guy I bought it from replaced the catalytic converter and related sensors, then drove the vehicle very rarely for a year. As mention, I bought it from him at that point.
So, yesterday I brought the vehicle in to a Subaru dealer for differential gear oil replacement plus oil change and a general checkover.
I'm given this estimate:
multiple oil leaks from valve cover gaskets,
cam seals leak,
oil pump o rings leak,
signs of coolant leak from water pump area.
Oil all over the bottom of the motor.
$1200 to fix oil leaks add $228 for coolant leaks. $600 just coolant leaks.
What gives? With the head gasket replacement this was all open up out 7000 miles ago. Would having the car sit around for a year dry out all these seals?
Questions: Is the timing belt/tensioner in jeopardy from these leaks? Is this estimate high? Can I keep on driving it safely until I decide what to do? Should I have the work done at a Subaru dealer or what it be safe to go with an independent garage?
I was planning on doing cv boots and half shafts myself but I need help with the motor.
Someone please chime in.
cam seals leak,
