1 - 2 of 2 Posts
1998 Suburu Forester
Does my 1998 Forester standard transmission have a flywheel inspection plate. I want to inspect the flywheel.
1998 Cayenne GTS 6speed
There is a big rubber plug on top of the engine (right side) that should give you some access - if you can get too under the intake manifold. There is a plate on the bottom but you're not getting it off without lifting the engine.
1 - 2 of 2 Posts
