Hi all,
I've got a 1998 Forester that I bought a while ago. I bought it for cheap as it needed the headgaskets changed. I've now changed the headgaskets and also changed the timing belt while I had everything apart. Now that it's all back together though it cranks but wont start. If I spray some quick-start into the intake and try it, it fires up but wont stay running. I've scanned for codes and have the following:
-P0261
-P0264
-P0267
-P0270
I've tried the following:
-comparing the resistance between injector terminals on all 4 Injectors (all at ~12 ohms)
-Checking resistance between the injector connector and the main connection in the engine bay for all injector plugs (All under 1 ohm)
-Checking voltage between ECM connection and chasis ground
Has anyone ever encountered this issue before? Is there something central to all 4 injectors that could be causing the code for all 4 of them? I've read around on here and found a few old posts but none really with a solution. Any tips/ideas/things to try are appreciated. Thanks!
-P0261
-P0264
-P0267
-P0270
