2004 FSTi 6 speed manual
Same size on UK s turbo and FSTi so don't see why they'd be different on an stb.
Hi, thanks I was away from the car, so couldn't see size of driveshafts....I've got them off now and thay are the same, thank you for the reply👍
2003 EJ20K Forester
If you want, I would suggest you take a tape measure and estimate the length from transmission output shaft to hub and see if they are actually the same L&R. I suspect they are slightly different lengths in reality. However, the L and R axles are the same part. Not sure what you are doing, but it might be worth noting that one side could make use of a slightly longer axle.
