1 - 15 of 15 Posts
1999 forester s turbo
Right, my spark plug sockets have finaly arrived so I am going to service the car tomorrow. I have never serviced a car before so it's all a bit new to me.
I know it's not hard but I cant find a basic service guide on here anywhere, so I need to ask a few questions.
I have oil filter. fuel filter, air filter, a set of NGK platinum plugs and some oil. I'm thinking I may as well do the coolant as well, Whats the ratio of coolant/water? I will do the brakes in a few weeks. Is there anything else I should look at while I'm there? Bearing in mind that over the summer I intend to clean/replace all components under the bonnet bit by bit.
2002 SG XT Auto
I go 50/50 with the coolant.
4 ltr of oil.
Never done fuel filter but i hear its a PITA.
Spark plugs are fairly easy IMO but people have had some real trouble getting to them.
Hoover out the air box when changing the filter.
2007 Outback Manual
Fuel filter is easy as long as you depressurise the system. Either run the engine with the fuel pump fuse removed, or do like I did and just leave the car overnight and change the filter before running the engine again.
MY11 WRX STi Sedan 6MT
remember when changing coolant turn your heater to hot fill it sssslow and i mean slow less chance of air locks then
On Subaru's the Heater core is full flow, therefore doesn't need the heater turned to hot - temp is controlled by flaps not a water flow valve.
1999 Forester
So where is the fuel pump fuse? The last time I changed the fuel filter on my Legacy I got sprayed in the face with gas as I took off the fuel line off the filter. I have a Forester now and should probably change the filter... my friend drove my car till it ran out of gas last week and it just doesn't seem to run right, now.
none none
Just let it sit overnight. Its also possible the pump is failing now, mine began failing and then when ran dry it killed it.
1999 Forester
Well filter change went well, no gas in face, Thank you. But now there is a problem, two days later it no longer starts, so I believe you're right about the fuel pump.... And wonder of wonders, a friendly mouse family built a nest right on top of the pump access, and their wonderful presence rusted everything, I don't know if I can get these nuts off without breaking something, and the already tough hose connections will probably be tougher!
1 - 15 of 15 Posts
