1 - 2 of 2 Posts
I need to get a button for the rear +12 plug so i can have constant power when my fridge is plugged in.
Also need usb outlets for the kids in the rear seat(like the outback).
anyone in here done this before me? If i have to run a new wire i can power both, what way is the smartest when going from the battery?
2001 Forester
There are holes in the firewall near the brake master cylinder that will allow you to run RED(+12) and BLACK(-GND/NEG). From there go through the center console, in between the Driver and Passenger seat. And then you can probably drill a couple of holes for the required outlets need in the rear of the center console. I have attached a picture of the hole in firewall, the power brake assist is just to the right of the hole where are all wires enter the passenger compartment. This hole shows up near the brake pedal. Note that if you connect the red/black directly to the battery, any device you have plugged in will remain powered up even with engine turned off.
1 - 2 of 2 Posts
