2018 2.0 XT Lineartronic CVT
I want to wire up a few extras properly in the Foz so wanted to know if anyone can advise me on the following please.
1. Best point to pick up a Permanent 12v feed inside the car, centre console, (i.e. Not switched via ignition) thought there must be one at the radio?
2. Best point to pick up a switched (via ignition) 12v feed in the engine bay?
I could go hunting around with a voltmeter but thought I'd ask if someone's already been there? Preferably without too much strip down either!
Btw, 2006 XTEn
Cheers
2018 Not saying.lol forwards and backwards
What additional extras are you thinking of? As its all well and good taking a 12v feed from another source, but if the current draw exceeds the amps allowed for the wiring you will constantly pop fuses and worse case it could be a fire waiting to happen.
98 sf - gls manual
as said above, depends what you want to power, i usually use the cigaret lighter feed for one or the other depending if its ignition 'swithced' and have on many occasions run a perminant live from the battery as there are a zillion fuse type options for sale out there.
and yes always put a fuse in both options,
2008 Forester XT Sport 4EAT
Might have to look at your wiring diagrams a bit, but fuse No.10 is a constant +12V and is not utilized for anything in the car. It is a 10A fuse.
On my 2002 Impreza I tapped it for my key ring illumination mod, here's where I tapped into it:
I haven't checked if the SG Foresters have it in the same place or not, but it's a great constant +12V source.
Many Thanks for your reply Nepbug, very helpful with diagrams and pic's an all:Banane35:
All understood about current draw and fusing guys, I'm not putting anything in that would draw a heavy load but will of course use inline fuse where necessary.
Thanks again
