2009 Forester XT 4eat
car was running fine and all last week after took it over to a shop to install the engine mount, and transmission mount after that car stiff when turning but is normal when is parked
Does anyone know what might cost this issue?
and while driving on a turn sometime feel like the steering wheel got loose a little.
power steering wheel oil full
belt new replaced less than 3k
no steering wheel noise when turning
2015 Forester 2.5i Premium 6-speed manual
Not knowing exactly how the work was done and the condition of your Forester, I would double check the condition of the Power Steering system including the belt, including how tight it is or not. But at this point I would carefully check everywhere in the engine compartment and front suspension for something amiss. Last, but not least, check your tire pressures and set them to what Subaru wants when the tires are cold.
Belt was good amount tight , tire pressure is on standard. Don't know what should I look for at the pump 100% no leak or what so ever or no bubbles on the fluid. No noise ..friend said put some w40 on the steering rack but dont think that's the issue. Just odd
