Sometimes it’ll just turn over 3 times and then stop and then I’ll leave come back an hour or two later and it’ll crank just fine I’ve tried jumping same results battery tested good and starter doesn’t seem to have problems when its getting power so all that I can think of is left is the immobilizer I have noticed when it does tend to not start the security light will come on and stay solid while in the on or auxiliary position I’ve tried resetting everything (disconnecting battery for 5 min and reconnecting) and then cranked fine except odometer read “- - - - - -“ then I tried cranking it again and wouldn’t crank resettled everything again and no luck left came back on hour later cranked right up and odometer was back to normal any ideas or solutions?
