I was wondering if anyone could explain how I remove the center console where the shifter is located.
2004 Forester XT
This is a fairly common question. In the future, try to search the forums for "center console", "dash removal", etc.
I have an 04XT manual, so this may vary a bit. But....
Remove shifter bezel by pulling on the rear part, pull up, it pops right out. May be different for an AT.
If you need the center section out, you'll see two screws at the bottom of the center section, remove those, then center section pops out with several clips holding it in. That can be tricky, they can be tough, just take your time and use caution not to damage your dash. Here is a diagram of the location of the clips and screws. You will need to make an account on the site to see it. Once again, things may be different on an 07 like A/C knobs, etc., so do a search on here to see if you can find more info on an 07.
