2004 FXT
My first Subaru. Bought off the lot new in May of 2006. once my daily now just a weekend fun car with about 2 track days per year.
ENGINE
Internals
-EJ257 block - blueprinted/port and polished
-heads - resurfaced
-CP 100mm Pistons, pins, rings
-ACL Bearings Race Series EJ257 Rod, Main
-gates racing timing belt
-Killer B high capacity oilpan pickup
Bolt-On
-EQ Smog blockoff plates
-TGV delete
-APS 70 mm Cold Air Intake
-Perrin IC hose kit (black)
-Perrin TMIC
-Perrin Turbo Inlet Hose
-Hallman Pro RX MBC
-Blouch 18g TD05 Turbocharger
-Titek catless DP
- with blacktrax ECS
-Borla hush exhaust
-Kartboy exhaust hangers
-Perrin light weight crank pulley
-custom carbon fiber pulley cover
-custom aluminum radiator shroud
-STI Oil Pump
-Walbro 255 fuel pump
-Deatschwerks 1000cc Top Feed Injectors
-NGK Spark Plug Iridium 1 Step Colder
-Subaru Group N HD Engine Mounts
coming soon
-oil catch can
-remove AC
-oil cooler
-catless UP
TRANSMISSION/DRIVETRAIN
-STi short shifter
-ACT clutch HD pressure plate, street disk
-ACT streetlight flywheel
-Type RA cryo treated gear set
-Kartboy shifter bushings front and rear
-Subaru Group N HD Transmission Mount
coming soon
-carbon fiber driveshaft
SUSPENSION
-Tien type Flex coilovers w/ EDFC
-Cusco rear sub-frame brace
-Whiteline 22mm rear sway bar
-Whiteline “big top mount” front strut tower bar
-Perrin end links
-Whiteline camber bolts
WHEELS AND BRAKES
-Rota DPT 17x9 white w/ Dunlop Direzza Z1 star spec 255/40r17 (street)
-Mach V Awesome Wheels 17x9 w/ Toyo r888 255/40r17 (track)
-BF Goodrich SS brake lines
-ATE blue break fluid
-Front STi Gold Brembo Calipers slotted Brembo disks w/Brembo RT TS20 Brake Pads
-Rear DBA 4000 Series T3 Slotted Rotors w/Ferodo DS2500 Pads
EXTERIOR
-STi spec c front lip
-STi rear air diffuser
-blue “I” impreza badge (front)
-Fastline Motorsports rally style mud flaps (off car now)
-JDM side visors
-painted (WRB) Seibon carbon fiber cw II hood
-Aero Catch Hood Pins (lockable)
-JDM spec c roof vent
-Lamin-x yellow headlight film
INTERIOR
-Samurai Sword Handle Shifter
-Defi gauge pod with Defi BF 60mm imperial boost, EGT, oil pressure gauges
-autospeed OEM style dead pedal
-JDM S203 hazard button
-Sparco harness bar
-Schroth Profi II FE ASM harness'
-KEY!S Racing deep steering wheel 330mm
-NRG short hub
-NRG quick disconnect
-Sabelt GT130 seats
coming soon
-oil temp gauge
MISC
-Viper alarm with remote start
-COBB access port v2
-Pro tune by Ed @ EQ Tunning
-DRL mod
-JDM air spencer (Squash)
-Halotron fire extinguisher
POWER NUMBERS
-EQ
266hp/316tq
BIG THANKS TO
PMAutoworks
EQ Tunning
Speed Element
GST Motorsports
Suby Dude
Mann Engineering
