Hello all!
I'm new but have lurked a bit and have been trying to find a thread with the answer to my issue but so far have been unsuccessful so I decided to start my own and hopefully find the solution and share with anyone else with similar issues.
The car in question is my girlfriends 2006 Subaru Forester. I did a head gasket and timing belt on it this summer after which it had a cylinder misfire which was fixed with a new coil(the wires and plugs were replaced ~2 years ago). Since then it had been running pretty well then the cold weather arrived and now it wont start after sitting all night. It will crank over it just doesn't catch and run unless you give it a jump start then it fires right up and then it starts fine the rest of the day.
The battery is a brand new AutoCraft silver 500 CCA and I had it tested at Advance and it passed as well as the alternator. I checked it this morning before trying to start the car and it was sitting at 12.5v. It does get a CEL after refueling occasionally for a faulty gas cap but other than that it hasnt thrown any codes recently.
I'm not really sure what to test next so I'm looking for help. If more information would be helpful just let me know and I will clarify.
Thanks
Kevin
Thanks
Kevin
