1 - 8 of 8 Posts
2006 Forester DR6-AWD
bought this used a few months ago w/145k on it. Lately on startup it's been running rough getting a blinking CEL pending DTC shows P0303/P0304. after it runs a while it runs OK. CEL does go out. Any suggestions? coil pack? if so are are there 2 or 4 packs on this engine? Thx in advance--
Update - just did a visual and it appears to have only 1 coil pack for all 4 cylinders--is this correct? It looks easily accessible if that is the problem. Might go and replace it and see what happens.
2010 Forester 2.5 XPremium 4EAT
1 pack, 4 leads.
I replaced mine with those same codes, problem solved.
Tip
Use OEM coil and use opportunity to replace leads with NGK, makes a difference IMHO.
@edhackem welcome to the forum from Oregon! :biggrin:
Not completing your Public Profile could result in future threads you create being
until your Public Profile is updated!
1 - 8 of 8 Posts
