1 - 2 of 2 Posts
Hey guys. Just got my 05 forester and I noticed when driving I can lay into it and put the pedal to the floor and it seems to break up in power randomly throughout the power band. I also noticed I’d get like 10 psi boost full throttle sometimes and others no more than 5 psi boost. It is stock except I have an accessport and it’s tuned on 91oct stage 1. In neutral I can punch it and it seems to jump up a little in rpm then pause then it will jump up and then pause and then climb. It just doesn’t seem right and I wanted to see if anyone could throw some ideas my way. It would be greatly appreciated.
Thanks in advance.
2001 Forester STi 6spd with MapDCCD
If you havent already done so, look on COBBs youtube page for videos about datalogging. Once you have a decent idea of how it works, you can post datalogs in here for further analysis and feedback as to what may be causing the issue(s) at hand. Its difficult for a tuner to diagnose the root cause here based on your description. A datalog using the stock parameters will give us a much clearer picture of what the ECU is reading when you experience such a hiccup.
-Mikey
1 - 2 of 2 Posts
