So it seems as though I need to replace one of these two rubber hoses (D & E). It looks like E is leaking a few drops a day, but I may as well replace both at the same time. My question is with the removal of these hoses, am I going to have to worry about getting air into this part of the transmission? And if I'm not to worry, should I not even bother taking off the ATF drain plug since it's draining from these hoses?
I'll probably replace the filter since I don't know the history on it, and I'll make sure to measure how much came out so I know where to start when refilling.
Does the CVT come with a transmission cooler? If not, has anyone added one?
I would like my CVT to last as long and to make it as "bulletproof" as possible. I know heat to be one of the greater enemies of a transmission, so in theory, a cooler is a great preventative measure.
Thoughts and...
Driving to work today, and about 2 blocks from work the cvt started struggling / jerking from stop. It was like a feeling that it was struggling to find the right gear
Anyways, at lunch decided to drive down the block to fill up on gas, thought maybe it was a misfire or bad gas, but it wasn't...
Since Subaru has extended their CVT warranty to 10 years/100,000 miles for all 2014-2018 Foresters, there has been some concern in other threads about the longevity of the CVT after the 100k warranty runs out. So if you have a high mileage Subaru CVT (over 100k miles) please tell us about your...
Hi all, I've done lots of work to Subaru's but I am tackling my first manual transmission Forester. It is my bosses 13' Forester X. He wants to change the transmission and both diff fluids.
My question is Subaru told me the front diff and transmission are part of the same unit with one dip...
Hi all,
Long story short, I have a grinding noise coming from the front right hand side of my 2014 manual diesel foz.
It has a 2 inch lift in it and a few other mods but nothing serious.
The suspect noise is only heard when holding speed or accelerating slightly in 3rd and 4th gears. I can...
